Driver side wing problem
I have recently bumped my van and smashed the driver side wing I can only find a 2010 model panel with everything I need, I was wondering if a 2010 front wing would fit a 2005 plate.
If anyone could help me ASAP it would be much appreciated
Attached Files Thumbnail(s)
Did they make the M59 in 2010? Latest I've seen was 2009, but maybe the vans were made for a bit longer. Does the seller have any other parts that might give a clue?
(07-08-2018, 07:08 AM)cancunia Wrote:  Did they make the M59 in 2010? Latest I've seen was 2009, but maybe the vans were made for a bit longer. Does the seller have any other parts that might give a clue?
I’m really not sure! Not familiar atall with these vans! I’m assuming it should fit a 2005 model but the seller doesn’t know themselves! Really not sure if I should risky buying it!!
If you Google Berlingo vans you can find  the M59 version on a 60 plate (2010), must admit I didn't think they went that long.
I can't see why the wing wouldn't fit, there were no bodywork changes made from 2005 as far as I'm aware.
(07-08-2018, 09:42 AM)jj9 Wrote:  If you Google Berlingo vans you can find  the M59 version on a 60 plate (2010), must admit I didn't think they went that long.
Okay that’s perfect thanks for the info! I think I’ll just order it as in desperate need for one!
Let us know how you get on.
It does look like the earlier wing, the later one has a large swage line higher up the wheel arch.
Today 01:01 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
