07-08-2018, 09:02 AM (This post was last modified: 10-08-2018, 12:23 PM by Quin.)
In a little follow on from my previous thread... How the heck do i access the relay for the fan in the front bumper? Also does it have a fuse? My manual seems to say not? It doesnt run at all but i cant get at it to check voltages
10-08-2018, 05:31 PM (This post was last modified: 10-08-2018, 09:35 PM by Quin.)
Have now run a temporary feed from a spare fuse way in the fusebox ontop of the battery to the relay, everything now works as it should ie when hot or when activating air con, works on low speed too, so it is literally just this lost feed but all bay box fuses are good, i guess ill have to try and trace the cable next.
If its like the m59, their are MF fuses hidden below the top fuse tray in the engine fuse box and can only be accessed by drilling the rivets out, then pulling the top tray out. If it's an hdi, the fan fuse could also be in a little box hidden in the gap behind the passenger headlight.
The following 1 user says Thank You to Sol for this post:1 user says Thank You to Sol for this post • Quin
Thanks, i pulled up on the fuse box and pryed a couple of plastic tabs luckily didnt have to drill anything, and yes a little row of fuses were on the underside, a 50A is blown, why the hell cant they put this in the manual!!!!!
This thread can be moved into the solved section if required
Its been running on a 30A feed fine since and the original fuse is a 50A so i can assume its ok now, it did start back when we had the snow earlier in the year so i can only assume the front bumper got a gob full and it froze the fan or something, will be grabbing a new maxi fuse this week and putting back to normal
(12-08-2018, 03:05 PM)Quin Wrote: Thanks, i pulled up on the fuse box and pryed a couple of plastic tabs luckily didnt have to drill anything, and yes a little row of fuses were on the underside, a 50A is blown, why the hell cant they put this in the manual!!!!!
Hi, I have the low speed fan out, I was hoping you could tell me which fuse you replaced, doubt it's that since high speed works but just nosey ?
