Threads: 9
Thanks Received: 14 in 9 posts
Thanks Given: 3
10-08-2018, 06:39 PM
(This post was last modified: 10-08-2018, 06:42 PM by Lingo_Berlo.)
I have been left on the road 3 times already with a leaky AdBlue fault (computer first says "Engine fault" then a bit later "Emissions fault" before engine dies). This time it's done - dealer said a lot of them have AdBlue related problems and Citroen designed a new AdBlue tank with plastic parts since AdBlue (or Urea acid) eats metal and quick Google tells me it is not just Berlingo, Cactus and other AdBlue models have it even more common and it is probably close to a recall as it can get IMHO.
73 000 km on mine before neefing a new AdBlue tank replacement. Dealer said it lets me drive max 2400km before dying this time (computer cuts the engine). New modified AdBlue tanks are being produced now and mine arrives at the end of August if all goes well, meanwhile my holiday car travel plans are destroyed.
So if you have an AdBlue model, be prepared for a complete tank replacement if you encounter this fault (and it is quite common I would guess from what I researched).
Threads: 28
Thanks Given: 78
Not good news, thanks for letting us know, are they replacing them free of charge to everyone or are they pulling the out of warranty / not serviced by a franchised dealer card ?
Mark
Threads: 12
Thanks Given: 16
37
Thanks for the info.
I did suspect problems ahead with the adblue systems.
Threads: 9
Thanks Given: 3
11-08-2018, 05:55 AM
(This post was last modified: 11-08-2018, 05:56 AM by Lingo_Berlo.)
Not sure they cover non-warranty models, but thankfully the AdBlue models are new enough probably many if not most are still under warrany so should get a free replacement tank if they should encounter this problem. Delivery seems to be hectic as of now, I guess Citroen is just starting to see the serousness of the issue...
Threads: 15
Thanks Given: 46
5
Mine was recalled for new adblue cap but no mention of complete tank replacement. Mine was new in March ‘17 & New cap was fitted when car had fisrt service in Feb ‘18. The op mentions redesigned tank but in link to Peugeot forum it suggests problem is solved by fitting new ventilated cap provided no damage has been done to pump caused presumably by lack of vent on old cap? Mine had only done about 11k miles before new cap was fitted.
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 8
Are citroen still charging for replacement of these?
Have the dreaded emissions fault and EML on a 2016 100 bluehdi.
1 month out of warranty!!!!
Threads: 4
Thanks Given: 8
p.s. okay to drive whilst warning lights on. says I have 700 miles until starting prevented.
Threads: 0
Thanks Received: 2 in 1 posts
Just FYI, dont bother buying adblue from any shops or filling stations for like a 12 for 10L. Go to a fuel station with truck pumps and there is nearly always an adblue pump and its normally 60p ish a litre. even at mega expensive motorway service stations it is only 85p a litre...
The following 2 users say Thank You to cavematt for this post:2 users say Thank You to cavematt for this post
• boop, ron
