Threads: 16
Thanks Given: 1
I changed my citroen berlingo 1.9 engine to another working one. After all the wirring and connections, i cranked the engine it turns but the diesel is not reaching the injectors.
Do i have to update the ECU or The Key
Please help
2003
WYJ
1.9
Threads: 48
Thanks Given: 4
20
1. This should be posted under the correct model in the 'Specific Model chat' section.
(makes it easier for people to notice it when it drops off the recent threads panel)
Which year is your car, and which year is the replacement engine?
Did you try to reset the 'tilt switch' in the engine bay?
(A rubber covered button mounted somewhere on one of the walls)
Threads: 16
Thanks Given: 1
My engine year is 2003
Replacement 2003
Am not yet allowed to post
Threads: 62
Thanks Received: 715 in 612 posts
Thanks Given: 219
50
Have you bled the fuel system including at the pump ?
Failure to bleed will mean the engine will never start.
Serieal Berlingo owner
Threads: 62
Thanks Given: 219
50
Do you have a Haynes Manual ?? If not have a search on this site as there is one here for free download.
The section on bleeding is minimal but it does if I recall correctly show an image of where to bleed the pump.
Threads: 62
Thanks Given: 219
50
Ok going from memory, been a while since I owned a 1.9 .....
Follow the pipe that goes from the filter housing to the injection pump and where it enters you should see a bleeding point, seem to recall it is a small hexagon about 8mm. Slacken this off and pump the priming bulb / plunger depending on which year it is and when fuel comes out there will now be fuel at the pump. Next try starting the engine.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
Has the engine you have fitted got an immobiliser type solenoid on the pump? You will be able to tell because the solenoid will be covered by an armoured cover.
If so you will need to fit the pump off the old motor.
Threads: 16
Thanks Given: 1
Thanks for all the replies, i seem cannot find the bleeding point of the pump...i can see the black that is on top but the pump one no luck, anyone with a picture
