[Engine] 2008 1.6hdi - Anti Pollution Fault won't rev above 2500
Does anyone have a view on what might cause an 'Anti Pollution Fault' message on a 2008 1.6hdi, plus limp mode meaning no power and won't rev above 2500? The car has done approx 150k miles, new turbo and failed an earlier MOT due to excessive smoke which is what prompted the new turbo. I've been told the CAT is blocked but is there a sensor that would show this or is it maybe an egr problem or perhaps something much worse?
According to the VIN *9HX* there's no DPF
Thoughts welcome.
Thanks.
fuel pressure sensor
(13-08-2018, 01:37 PM)Tree Wrote:  fuel pressure sensor
You've jogged my memory ... Where else have I seen that?
Might have been my thread that you replied to not long ago when the fuel rail pressure sensor was being dicky in my 9HX?
https://www.berlingoforum.com/thread-17105.html
I don't have an informative display on dash but only the engine malfunction light. Have you scanned for codes? The cat is very easy to remove from this engine and has no sensors going to it. You could take it off and (carefully) see if it will rev past 2500rpm.
[-] The following 1 user says Thank You to Mankee for this post:
  • cancunia
(14-08-2018, 06:49 AM)Mankee Wrote:  Might have been my thread that you replied to not long ago when the fuel rail pressure sensor was being dicky in my 9HX?
Thanks, you're right it was probably your post that I saw. I wondered about taking the cat off as you suggested. It's not on my car but one I was looking at buying but have decided against it as there were other problems.
Also possibly one of my posts - happened to me in France a few years back in our C4GP
ServiceBox
Last Post: nonce
Yesterday 03:28 PM
Limp mode, no other symptoms.
Yesterday 11:37 AM
Adding aircon oil after component replacement
Yesterday 11:23 AM
Centre Air Vent On Dash
06-07-2025 10:50 AM
05-07-2025 11:41 AM
» Replies: 36
2.0 hdi clutch
05-07-2025 06:20 AM
Solenoide, Wastegate
05-07-2025 02:27 AM
All NS front head lamp bulbs blown?
05-07-2025 02:15 AM
Power steering Leak
Last Post: AugustinoHippo
01-07-2025 11:09 AM
install other safetywall
Last Post: mikeh79
01-07-2025 09:48 AM
