Threads: 4
Thanks Given: 2
How do I tell what model I have?, its a French import, into Spain, so the paperwork is all topsy turvey. I know its a 2013 Citroen 1.6HDi Multispace 5-Door, with rear door lifting upwards. It has factory fitted daytime running front LED lights and front fog lights. The black body parts are shiney. Your help would be appreciated.
Threads: 15
Thanks Given: 46
5
Difficult to answer because French supplied Berlingo have different specs to UK supplied Berlingos. Different trim levels & engine options etc. For example 110bhp & later 115bhp diesels only available on top of range in UK whereas in France engine is availble on lower spec models & so on. You can tell engine power from serial number on engine, I think.
Threads: 16
Thanks Given: 1
Check the vin number there should be a code. Or the seat belt. Drivers side
