[Engine] 1.6hdi dpf regen limit?
Is there a mileage or other limit to the amount of times a DPF can regen with needing intervention from Lexia / Diagbox?
I am not sure if I understand correctly your question...
The ECU software has an alarm-like limit for the number of automatic regeneration that can be done by a dpf filter, that is counted by the number of times you have open and closed your fuel filler cap (i.e., number of diesel tanks, that is proportional to the amount of EOLYS that has been burned by the car). In my case this alarm told me my dpf would need renewal circa 180000 km. When I refilled the EOLYS tank (around 170000 km) I also reset the DPF filter using Diagbox. It then assumed I had a new one, and this limit counter changed again. It now has 182000 km and still going, no alarms, no lights on, nothing bad about it.
This regen limit number for the filter depends a lot on your average driving conditions (on the amount of black smoke you actually produce while driving). If you drive a lot in the city, the 180000 km are very likely to be near the physical limit of your dpf filter. if you do lots of motorway, then this might be different, and it could last more, some say it might survive past the 200000 km (mine is on its way to this mark, let´s see).
If you have to force regenerations with the software more than twice, with lots of high-rev motorway runs in between, and the alarms still on, then it is likely that your dpf filter needs renewal...
Hope this answers your question...
Prima, ich danke dir!
Yes, that's what I had in mind. The car in question has over 210000 Miles, the EML is on & the dealer wanted money to reset it. So it was probably the number of tank refills and could also be that it really does need a new DPF. I did also read on another thread that if there can be problems with the fuel filler cap not making good contact and causing an anti pollution fault
(14-08-2018, 08:19 AM)cancunia Wrote:  Prima, ich danke dir!
Yes, it certainly can. actually any fault regarding the anti-pollution system (EOLYS pump malfunction, EOLYS calculated level, etc...), but for making sure wich ones you have you have to connect it to a Diagbox system and confirm the error codes that show. Other scanners/softwares will not be so precise as diagbox or the dealership´s software...
Replacement TPS Sensor
Last Post: Jamespworth
Yesterday 07:38 PM
Juddering when pulling away
Last Post: cancunia
Yesterday 07:07 PM
Hello new member and warning light issues.
Yesterday 07:06 PM
Aux cord functionality
Last Post: mistervanman
Yesterday 06:35 PM
B9 Head Unit Upgrade
Last Post: manuk
Yesterday 06:18 PM
Driver door lock problem help!!
Last Post: ffrenchie
Yesterday 07:42 AM
Can i get away with 205/70r15
20-04-2019 11:38 PM
How I installed an oil catch can in the 1.6HDi
Last Post: saskak
20-04-2019 09:59 PM
Eco-mode behaviour . . . .
Last Post: Lighty
20-04-2019 09:46 PM
Witter PG46C Towbar 2008 on
Last Post: Jakejjt
20-04-2019 08:28 PM
