Threads: 16
Thanks Given: 1
On a 1.9 berlingo when i install a new engine do i have to put my old pump..in order to supply the injectors with diesel or
1.9
2003
WJY
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
I think the pumps are coded to the ECU. They talk to the ECU and the ECU tells the pump the settings , so either change the pump for the original or change over the sensors/control unit on the pump if possible .
There were some old posts about the same problem and changing the pump was the way to go. (I think )
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 123
Thanks Given: 250
34
There's an immobiliser over the fuel cut off solenoid on the fuel pump, it's paired with the ECU. You can get around it by cutting the casing off that houses the immobiliser and replacing the solenoid with one that is switched by the ignition. There are quite a few posts elsewhere about this with more detail on here & elsewhere.
Threads: 9
Thanks Given: 316
15
good advise so far zweli ^^^^
Threads: 16
Thanks Given: 1
The cut off solenoid is located where.is it the black thing on top of the pump with three wires.
If yes i removed it and I installed it to the new pump...from the original
Threads: 9
Thanks Given: 316
15
I think you need a decent manual mate? The solenoid is on the pump and is shaped like a cut off solenoid tbh
