Threads: 2
Hi
Has anyone on the forum done any work on the full length sunroof.
I have ordered the cable set (must be made of gold or something similar as they are £180)
I'm not sure if I need to remove the whole sunroof to change the cables, or if they can be changed with the roof in situ. Any help would be appreciated.
Threads: 147
Thanks Given: 263
11
From memory I don't think it's been discussed yet, doesn't stop us being able to help you out though!
Threads: 19
Thanks Received: 18 in 11 posts
Thanks Given: 21
23-11-2011, 09:12 AM
(This post was last modified: 23-11-2011, 09:12 AM by jamesf.)
Ours hasn't worked for three+ years - also needs new cables and a motor and were quoted £1700 so we've taped the thing shut and left it at that!
Been looking for a scrapyard sale ever since
But I think it'll be a job to do
Remove the roof lining which will be fun (well, replacing it will!) then you should be able to see / access everything.
It'd be really useful if you could take photos and put them up - as this would / will help me (and others) in the future as these are a great feature (when they work) and it'd be good to keep them going!!
Good luck!
