[Engine] 1.6HDi - acceptable play on turbo shaft?
I've read that some play is to be expected due to the bearings running on a film of oil.
Just wondered if anyone has a view on an acceptable amount of play for a turbo shaft?
this is excessive Smile but i ran it down the 1/4 mile like that tho
https://www.youtube.com/watch?v=hVxRi96z5mo
Check the play on your 2.0 hdi turbo then use that as a comparison.
(18-08-2018, 11:21 PM)jj9 Wrote:  Check the play on your 2.0 hdi turbo then use that as a comparison.
I'd rather not know!
(18-08-2018, 04:16 PM)cancunia Wrote:  I've read that some play is to be expected due to the bearings running on a film of oil.
Hi Cancunia,
I also wondered about the acceptable amount of play for the turbo shaft. Mine (M59 1.6HDi, 2007, 9HXC engine, ~88k miles) has a slight play, ~less than 0.5mm, but I can feel it moving slightly when shaking the shaft. I have not had any problems, so I suppose that is relatively normal.
Cheers,
Saskak
smile, you are alive!
[-] The following 1 user says Thank You to saskak for this post:
  • cancunia
Thanks for the info. Apart from the strange whining noise which I think is the aux belt & the Antipollution Fault which I think is the MAF (at least according to the OBD code), the engine is running really well so I'll keep the pipe on the end of the turbo for now and refer back to this thread in case of trouble down the line.
You can just feel very slight play just enough to leave enough room for an oil bearing to form.
  • saskak
tensioner pulley
Last Post: RJBingham
Yesterday 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
clutch pedal
Last Post: gissa
14-02-2019 12:43 PM
Engine noise
Last Post: cancunia
13-02-2019 12:40 PM
» Replies: 16
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
Last Post: ffrenchie
12-02-2019 04:23 PM
» Replies: 31
New Berlingo Anyone????
11-02-2019 11:13 AM
