Threads: 2
Thanks Given: 2
19-08-2018, 03:05 PM
(This post was last modified: 19-08-2018, 04:50 PM by Mike.)
Hello i'm currently having some issues concerning the front brakes sticking have replaced the calipers.it seems to build up pressure in the system as you drive making the brake pedal hard. But if you push the pedal down hard it seems to release the pressure. Any advice is very much appreciated
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi - I've seen this when the flexible brake pipes were clamped with mole grips/whatever during a caliper swap. Result was like yours - the pipe was collapsed internally so would not let fluid back out of the caliper under normal braking but when you really pumped/stood on the pedal it would open up the crimped bit and let some of fluid back up into the system.
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
The following 1 user says Thank You to GraemeT for this post:1 user says Thank You to GraemeT for this post
• keith1969
Threads: 9
Thanks Given: 316
15
Could be as above ^^ or master cylinder sticking.
Threads: 9
Thanks Given: 316
15
Why did you change the callipers - because the brakes were sticking?
Threads: 9
Thanks Given: 316
15
Well it may still be the flexi hoses but you were already having a problem when you clamped the hoses to change the callipers.
The fact that if you hit the brakes again, hard, and they free off suggests the master cylinder to me - if it were the hoses it would more than likely cause the brakes to stick constantly.
• keith1969
Threads: 8
Thanks Given: 305
36
20-08-2018, 06:37 PM
(This post was last modified: 20-08-2018, 06:40 PM by jj9.)
