1.6i cooling issue.
Hi
I’ve got a 2004 1.6i that the fan won’t come in on. Can’t seem to find a fan switch anywhere, can someone point me in the right direction please? Many thanks in advance
It won’t have a fan switch, chances are it’s the fan or the wiring and relays associated, it takes temperature from the engine ecu and the engine ecu switches the fans in and out, two relays if it’s a single fan with a resistor
Time to break out the multimeter if you have one as it’s not gonna be nice and simple if a fans packed up
[-] The following 1 user says Thank You to dumdum for this post:
  • Lovebus
(23-08-2018, 11:56 PM)Thanks for the pointers everyone. Sorted now?dumdum Wrote:  It won’t have a fan switch, chances are it’s the fan or the wiring and relays associated, it takes temperature from the engine ecu and the engine ecu switches the fans in and out, two relays if it’s a single fan with a resistor
So what was causing the problem?
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
