Diesel filter replacement - 2.0hdi
Hi all
Thinking of changing the diesel filter on my '04 2.0hdi
( Siemens type housing with screw on collar ) .
Haynes manual makes it sound tricky , but watched a few videos online ( one in French - one in Russian ! )
that made it look simple enough .
Anyone got any advice ?
Pretty easy but the rings can be very tight so a very large pair of pipe grips helps
  • Blackshuck
Believe me, you need one of these.
£12 well spent & you won’t believe how easy it is.
Ensures you tighten it correctly also
https://rover.ebay.com/rover/0/0/0?mpre=...1610251020
[-] The following 2 users say Thank You to Lighty for this post:
  • Blackshuck, polar
There is a rubber tube hanging down inside my engine from the bottom of this diesel filter, is the other end meant to be connected anywhere?
I have never driven a diesel before and all seems well (and smooth) just looked dodgy...
I have 2003 2litre HDI Multispace.
(29-10-2021, 07:55 AM)CherryBomb Wrote:  There is a rubber tube hanging down inside my engine from the bottom of this diesel filter, is the other end meant to be connected anywhere?
It's probably the drain hose. Diesel filter housings often have a drain cock / plug to allow the fuel to be drained so that any water that has collected in the filter can be drained out, it also makes it a bit less messy to change the filter.
  • CherryBomb
just done mine today very easy to do 2.0 hdi engine 2004 reg  [/url]
[Image: 251770788_590701942261122_51343542571221...e=61A6751F]
Your Story
[Image: 71917943_137788567552464_852993435414141...e=61A6B174]
[url=https://www.facebook.com/stories/113979566600031/UzpfSVNDOjE0OTMzMzQ0MzEwNDE2MjM=/?bucket_count=9&source=story_tray]do here is a pic off mine . mine also is a 2.0 hdi
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
