Smashed my wing mirror off
Stupidly backed into a wheelie bin and took my passenger mirror off in the process! It’s an electric one and I’ve ordered a replacement on eBay. I should have asked first but the electric mirror on a multi space is the same as the panel van right? Also it’s a coloured mirror, can I take the colour coded bit off so it’s just black or is it more complicated than that? Cheers
The colour coded part will unscrew / unclip from the inside.
Outer mirror 'sheath' should just spring off, with a bit of manly persuasion. you can then rattle can it to whatever colour you choose.
Gravity
all I needed to know! Thank you fellas Smile
Hope you have better luck with an Ebay mirror than I did:
https://www.berlingoforum.com/thread-16040.html
(30-08-2018, 10:07 PM)gotoberlin Wrote:  Stupidly backed into a wheelie bin and took my passenger mirror off in the process! It’s an electric one and I’ve ordered a replacement on eBay. I should have asked first but the electric mirror on a multi space is the same as the panel van right? Also it’s a coloured mirror, can I take the colour coded bit off so it’s just black or is it more complicated than that? Cheers
I also did a similar thing in a car park, backed into a pillar and broke the mirror. I bought one from halfords, but what I found was that the internal support for almost all replacement mirrors is plastic and the mirror vibrates/shakes slightly while driving. This gives a somewhat fuzzy image. The original mirror has a metal support, so I used the original metal support with the new mirror and it is perfect.
Cheers,
saskak
smile, you are alive!
tensioner pulley
Last Post: RJBingham
Today 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
clutch pedal
Last Post: gissa
14-02-2019 12:43 PM
Engine noise
Last Post: cancunia
13-02-2019 12:40 PM
» Replies: 16
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
Last Post: ffrenchie
12-02-2019 04:23 PM
» Replies: 31
New Berlingo Anyone????
11-02-2019 11:13 AM
