Swapping a mirror, where's the wiring?
I've removed the door card off of my Berlingo panel van 2005 ready to swap a mirror that I smashed off, but it's just a layer of polystyrene underneath and I don't want to rip it unnecessarily. Where's the wiring located to swap and replace my mirror? Thank you
The wiring should be in the mirror, the mirror is screwed to the door so maybe there's a small plastic cover that needs to come off from the inside where the mirror is mounted.
  • gotoberlin
You do need to get under the foam layer to reach the plug. I just ripped mine but later read you can probably run a knife through where it's glued on to remove it more neatly, then re-glue.
Engine noise
Last Post: cancunia
Yesterday 10:03 AM
» Replies: 21
clutch pedal
Last Post: ffrenchie
20-02-2019 08:06 AM
tensioner pulley
Last Post: RJBingham
17-02-2019 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
12-02-2019 04:23 PM
» Replies: 31
New Berlingo Anyone????
11-02-2019 11:13 AM
