Door mirror wiring diagram?
As anyone found a wiring diagram for the door mirrors (2009), mine has failed its mot ( in France) on the left hand mirror not moving left to right via the switch. Motor is ok, also bought new switch and its not that, any ideas? tia
I can't help with the wiring diagram, but unless I am mistaken the mirror only needs to be usable ?
You can see through it ?
You can adjust it by hand ?
Therefore it works. I'd politely query the MOT tester where it says the electrics have to work. I can lean out of my window and adjust mine, while driving.
From https://assets.publishing.service.gov.uk...irrors.pdf
iv) each interior mirror shall be capable of being adjusted by the driver when in his driving position;
(01-09-2018, 02:49 PM)YTC1 Wrote:  I can't help with the wiring diagram, but unless I am mistaken the mirror only needs to be usable ?
Sorry, forgot to say it was a french mot (CT)
French? Then all bets are off :-)
Sent from my Moto G (5S) using Tapatalk
Timing belt change interval
Yesterday 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
