Newbie Hello1
Hi All,
new member TJ here, recently bought a '15 berlingo, it has been going fine until today when i got stranded, I am now here to try and get some help with this! van doesnt start, just clicks when you turn the key, battery is fine, alternator is new, so i suspect there is something wrong with the starter motor! only done 26000ml. Does anyone know where it is so i can check for loose wires and save me searching through hundreds of threads! Van doesnt drive currently and is my only works vehicle! so it needs sorting quick!
will scan through some of the threads first though to try and find an answer, unless someone comes through before i find an answer!
Thanks guys
TJ
Welcome to the forum TJ - if you want to change your username as email isn't the usual done thing, please PM me with your desired name and i'll get it updated.
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
