[Engine] Engine doesnt turn, just clicks
Threads: 2
Hi All,
I have 2015 berlingo van, only done 26000miles, a few weeks back the van just didnt want to start, turn the key and you just here a faint click, sat there for about 20 mins checking wiring in the engine, couldn;t find anything, but it started, then today i get stranded when it did it again ,RAC had to come out and get me home, we did manage to bump start it to get me going but i linped home and its now on the driveway dead as a dodo! can someone please tell me where the starter motor is, i just want to check the wires and make sure nothing is loose. next step after that is off to the shop to be properly looked at!
thanks in advance!
TJ
Threads: 28
Thanks Given: 78
Hi TJ,
Take a look at this thread and see if the information relates to your problems.
https://r.tapatalk.com/shareLink?url=htt...are_type=t
Mark
Threads: 2
(04-09-2018, 04:07 PM)Satellitemark Wrote: Hi TJ,
Mark
Mark,
Thanks for the link, it does sound similar, and it confirms my thoughts, the starter motor is a pain to get to as well, i cant even see it and cant find a Haynes manual to tell me where it is.
i've got someone picking the thing up tomorrow to have a go at fixing it.
TJ
Threads: 12
Thanks Given: 16
37
Starter motor is horrid to change on the 1.6 hdi. At least takes up to 2 hours , even when you have changed plenty !
Threads: 20
Thanks Given: 7
15
(04-09-2018, 03:29 PM)dsilvaterence1@yahoo.co.uk Wrote: Hi All,
thanks in advance!
TJ
Silly question - have you checked the battery as it will almost certainly be an AGM type - i had just over 2 years out of mine before I had to replace it.
Threads: 2
(05-09-2018, 12:47 PM)Tree Wrote: (04-09-2018, 03:29 PM)dsilvaterence1@yahoo.co.uk Wrote: Hi All,
thanks in advance!
TJ
Silly question - have you checked the battery as it will almost certainly be an AGM type - i had just over 2 years out of mine before I had to replace it. yeah, battery is fine, alternator is also charging well, so that leaves the starter motor as the most obvious candidate. thing got picked up today, so someone else can struggle with it!
Threads: 28
Thanks Given: 78
Any progress ?
Mark
Threads: 2
yes, it was the starter motor, all replaced and working again!
driving it back from the garage i noticed a vibration/fine juddering when turning the steering wheel, only when turning a lot, like when you turn out of a street or into a road. small corrections make no vibrations, and no vibration when braking.
any thoughts? power steering pump on the way out? have never had this much go wrong with a berlingo, owned it for 2 months.
Threads: 123
Thanks Given: 250
34
(07-09-2018, 10:34 AM)dsilvaterence1@yahoo.co.uk Wrote: yes, it was the starter motor, all replaced and working again!
There are some threads on here about the steering behaving strangely if the steering is turned while the wheels are off the ground. Maybe that's what's happened?
Threads: 2
Yes, i have come across these threads, thanks, im hoping its just that, as the power steering fluid tank is full.
thanks
Yesterday 05:06 PM
Yesterday 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
