Threads: 16
Thanks Given: 1
I removed this cause my fuel was not getting to the enjectors, what is this and how do i test it if it work...off the car
Thumbnail(s)
Threads: 48
Thanks Given: 4
20
Could you post a couple of better pictures, preferably one with the doodad stil mounted in the car?
The following 1 user says Thank You to Gadgetman for this post: 1 user says Thank You to Gadgetman for this post
• Zweli
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
It looks like a solenoid.
Threads: 65
Thanks Received: 715 in 612 posts
Thanks Given: 226
50
Test by applying +ve battery voltage to the single cable and earth the casing back to the -ve battery terminal and the internal plunger should move.
Serieal Berlingo owner
