Airbag light
I have a 1.6 Hdi XTR 2010 model and the airbag light came on and a message says Airbag seatbelt tensions faulty as I went to put the car in my garage last night anybody got any ideas what the problem could be thanks in advance.
2010 Citroen Berlingo Multispace XTR 1.6HDi in blue
Had a look under both seats and cleaned the connections but still no joy looking like I have to get CODES read to see if it can give me some idea what the problem is.
Update had the car CODES read the code reader said the problem was N/S rear passenger side area.  Going to strip N/S of car and check all connection and then have the CODES re-read on Monday as advised by the garage.
Had another look at car today does anybody know do the 2010 Citroen berlingo Multispace XTR have seat belt tensioners on the rear seat belts as I can't find any wiring  as code reader is pointing to N/S/R seat belt
Does a permanent code need to be cleared by code reader or does it clear it self.
Thanks in advance
I am quite sure that there are no pre tensioners on the rear seats, cannot help you about code readers.
[-] The following 1 user says Thank You to Trevor for this post:
  • Washeymag
The car is now sorted took car back to Citroen and Peugeot specialist and had CODES re read same fault which proved to be a ghost fault the only people to sort this is a Citroen dealer.
So the specialist booked the car into dealers who refreshed the software on the Airbag ECU and also found corrosion on one of the connectors and had to replace the connector.
The total bill was £80 from the specialist which I thought was reasonable.
Thanks Trevor
[-] The following 2 users say Thank You to Washeymag for this post:
  • Art b, CherryBomb
sliding door panel removal
Last Post: mojito
23-03-2025 07:35 PM
XL tyres
23-03-2025 06:57 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
