Threads: 3
Thanks Received: 1 in 1 posts
Thanks Given: 2
Just a quick question. Ive just baught a 2007 1.6hdi berlingo with a dpf filter on it. Is there a tank on these for fluid and is it easy to find. Cheers
Threads: 9
Thanks Given: 316
15
Hi Rob, yes it does it has an eloys fluid bag under the vehicle n/s usualy. You usualy just fit a new bag of the stuf but you then have to reprograme the ecu to let it know.
Eloys fluid is highly corrosive stuff so be very careful if you are going to do it yourself.
They need topping up anyware between 50-80k
• Rob.nixon
