[Engine] Not emissions
Hi, I will start by saying this subject may have  already  been covered on here, my van is due its annual mot and with the new regs in force I am asking you members have you encountered problems with emissions, my van is a 1999 on a "t" plate and although is very reliable it does put smoke out occasionally . To get to the point (sorry I am waffling) are m o t testers allowing any movement on emissions on older diesels. Thanks in advance
No retrospective changes are applied.
I think the only concessions are made for vehicles from the 80's or earlier. IIRC the way the smoke test is done is to first rev the engine to purge any unburnt fuel, then test at about 2500 rpm or half the max revs whichever is the lower. So, if your smoke comes out when accelerating, it should not be so bad.
May be worth getting some Millers or injector cleaner in a near empty tank and doing an Italian tune up on the way to the MOT.
If she is running well you will be fine give it a good blast before the mot.
[-] The following 1 user says Thank You to V6BOY for this post:
  • Art b
(19-09-2018, 02:10 PM)V6BOY Wrote:  If she is running well you will be fine give it a good blast before the mot.
Well it has past its mot, I used a fuel treatment as advised by a member along with egr cleaner. The van is 19 yrs old  and 101,000 miles on the clock, we don't use it much but it is a handy van when needed.thanks for your input and advice
[-] The following 1 user says Thank You to 1961ed1961 for this post:
  • Art b
Good to know.. Cool
Thanx
called Brian... Smile
Users browsing this thread: 2 Guest(s)
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
