  • 15 Vote(s) - 3.4 Average
battery light
i have just bought my van and the battery light is on, when i went to get it the battery was flat, so jump started it and drove 30 miles home in the dark with the headlights on, so im sure the alternator is working, but i have put a new battery on but the battery light is still on?
Measure the voltage at the battery terminals while the engine is running.
You should see about 13.8 volts. If it's less then check the earth connections for corrosion or loose connectors. If the voltage goes up and down with variations in engine revs then it could be that the voltage regulator is at fault. The regulator is part of the alternator and I believe that you can buy the regulator as an after-market kit but I'm not sure on this but there is a recent post suggesting that these are available. If the alternator, as you have said, is OK then there are a few connectors that may not be as tight as they should be or are corroded.
I hope this helps. :thumbsup:
  • Danz37
I have something similar.
Sometimes when I'm sat at junctions with the engine idling, the battery light will momentarily light up and bleep. doesn't do it when first fired up when sat on the drive, or parked up with the engine running, only occasionaly when i pull up at junctions.
Lights don't go dim or anything and all the rest of the electrics seem in order.
The voltage is sitting at 11.4 with the engine at idle and it rises about .3 when its at 3k rpm,il check the straps then start looking for a new regulator.
(25-11-2011, 07:04 PM)Danz37 Wrote:  The voltage is sitting at 11.4 with the engine at idle and it rises about .3 when its at 3k rpm,il check the straps then start looking for a new regulator.
If that's with the new battery then I'd say that there's little or no charge from the alternator. A good battery should read at least 12v and your is less so there is a discharge which will get worse. You need to get this fixed or you could risk the new battery as well. :eek:
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
