My Berlingo is a 2005 1.6 multispace. A year ago my left headlight bulb suddenly exploded! I had to remove the intire light to emty all the debris from the bulb and to clean the inside surface. All went well, except now there is a slight horisontal misalignment compared to the right one.
I can easily adjust vertical, but I have not been able to find a horisontal adjuster, is it not possible?
Jan from Denmark
Threads: 29
Thanks Given: 67
20
Is the bulb seated properly ? If a bit of your debris is under a locating tag of your bulb it will be pointing to one side and will upset the alignment or you have not seated the light unit properly.
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• Art b
ffrenchie,
"Is the bulb seated properly ? If a bit of your debris is under a locating tag of your bulb it will be pointing to one side and will upset the alignment or you have not seated the light unit properly."
No, that´s not it. But if it really is impossible to make a horizontal adjustment, then I might just use this means to counteract whatever has happened to the headlight inner reflector.
