Which gaskets
My 2004
1.9d has oil leaks from the top of the engine,
It's been badly bodged with mastic  Dodgy
Do I need 2 gaskets,
 anyone recommend ones to buy... Huh
Thanx in advance....
called Brian... Smile
https://www.catcar.info/citroen/?lang=en...BwbGllcj09
Item 20 may be what you need, plenty on fleabay
  • Art b
That is if it has gaskets , some don't and rely on a bead of silicon to act as a gasket. If there is a groove round the cover then its a gasket you need , if not a tube of silicon has to do as a gasket has nowhere to sit in and will squeeze out when pressure and heat is applied. Some sumps are the same set up .
You don't know until you take off the cover.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • Art b
Some years ago on a 55 plate 1.9d I needed new gaskets and found the top one was available from a motor factors and the bottom one was only available at main dealer as part of a full engine seal and gasket kit for well over a £ton.
I bought the top one and used "mastic " sealant for the bottom without issue.
As post above you need to look and see / ask at dealer with reg no to see what is needed.
With mastic it is best to read the manufacturers instructions and also seek advice if not familiar with its use for to just apply the stuff and wind down the fixing bolts untill they go tight generally doesn't work that well.
  • Art b
(25-09-2018, 08:32 AM)brodfather11 Wrote:  That is if it has gaskets , some don't and rely on a bead of silicon to act as a gasket. If there is a groove round the cover then its a gasket you need , if not a tube of silicon has to do as a gasket has nowhere to sit in and will squeeze out when  pressure and heat is applied. Some sumps are the same set up .
I did wonder... Dodgy
I've used blue gasket compound before,
you apply then let it dry before assembly..
Thumbs Down
(25-09-2018, 09:27 AM)geoff Wrote:  Some years ago on a 55 plate 1.9d I needed new gaskets and found the top one was available from a motor factors and the bottom one was only available at main dealer as part of a full engine seal and gasket kit for well over a £ton.
I was thinking along those lines... Wink
thanx..
(25-09-2018, 07:01 AM)cancunia Wrote:  https://www.catcar.info/citroen/?lang=en...BwbGllcj09
Cheers I will take a look...?
Look also at item 25 re my earlier reply
  • Art b
[attachment=4271]
Stripped the covers of the engine..
Looks like someone's had a go with sealant,
it's been leaking in various places
This looks like the answer... Tongue
£3.50.
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
