Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
My 2004 1.9 has a very hard to depress cable operated clutch ..
is there a way to improve it..?
called Brian...
Threads: 9
Thanks Given: 316
15
The bushes in the bellhousing can dry out and wear a good spray with GT85 every so often helps, lube the clutch cable and check the routing of the cable.
A heavy clutch can also be a sign of the clutch near the end of its life.
• Art b
Threads: 24
Thanks Given: 487
Thanx will investigate those
called Brian...
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
Normally when the clutch gets heavy it needs replacing in most cases in my experience
The following 1 user says Thank You to dumdum for this post:1 user says Thank You to dumdum for this post
• Art b
Threads: 123
Thanks Given: 250
34
Not sure if you're comparing it with other Berlingos?
The cable operated clutch pedal is heavy going anyway so it may just be that you're not used to it.
Threads: 11
Thanks Given: 16
8
Quite the opposite, a well done and greased clutch and splines will be lovely and relatively light, and very similar to a hydraulic effort as it’s the same throw on the pedal and the same pressure to release the pressure plates
The cable induces very little drag, obviously after 110k miles it may become a little heavier, but when it starts getting noticeably heavy it’s because the change has become bigger so you notice, rather than gradual changes when it’s younger if you see what I mean... I’d put money on it the clutch is on its way out... I’ll await the squealing release bearing post soon, as when it wears the fingers lose leverage ergo pedal feels heavier and the bearing gets three times the pressure applied, this soon wears the bearing out
• Art b
Threads: 123
Thanks Given: 250
34
Make sure everything is lubricated & as dumdum says, wait for the squeal, it may never come.
Without trying my left foot on your clutch, it's impossible to say for sure if yours is more difficult than mine, or if there's already a problem. I drove over 15k miles up to 123k in my 2.0 HDi with a 'heavy' cable operated clutch, it was still working fine when I sold it. There's a very real difference between the 2.0 cable & the 1.6 hydraulic clutch that I have now so I'm sure that one is heavier to use than the other. IIRC there's also a big spring on the clutch pedal to assist your left foot.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• Art b
