Threads: 7
Thanks Received: 42 in 35 posts
15-12-2018, 07:25 PM
(This post was last modified: 15-12-2018, 07:28 PM by hawaiianblue.)
pipe will likely be standard 6mm outer diameter.
You can bend the copper/nickel pipe without a tool, but it's normally neater when you do use a tool.
Threads: 15
Thanks Received: 102 in 92 posts
Thanks Given: 15
6
Hi - look into getting one of these in the correct size for the pipe you buy :
https://www.ebay.co.uk/i/252308824962?chn=ps
For operating in narrow places very highly recommended
Our cars 2008 1.6 HDi 92 Berlingo (His) RIP 2019
2008 1.6 HDi 110 Mini (Hers)
2008 1.6 HDi 143 Mini (His)
Threads: 29
Thanks Given: 67
20
Does the Berlingo use imperial or DIN flares ?
Threads: 15
Thanks Given: 15
6
Flares are the DIN/ISO type - I use 3/16" OD cunifer pipe and 10 x 1mm fittings and a 'Powerhand' tool. They come with DIN or SAE punches/dies so you need to buy the correct one. Bending tool is a D cell battery to bend the pipe around. Trick is to practice a lot first and, even the, double check you have popped the fitting onto the pipe (the correct way round) before you flare it.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Please don't use a D cell or other plain cylindrical object to bend pipe. It ends up flattening the pipe.
Maybe 6mm brake pipe survives without deforming too much and putting restrictions on the liquid flow, but why take the chance. A flattened pipe is very difficult to 'unflatten'.
And a cheap bending tool can be found for £10.
If that isn't available, take a piece of 1" roundstock, or a broom handle and carve a 6 - 7mm wide groove with rounded bottom around it and use that.
Threads: 8
Thanks Received: 498 in 447 posts
Thanks Given: 301
31
I would advise copper pipe, it's a lot easier to bend and shape than the Kunifer (copper / nickel) stuff.
Threads: 123
Thanks Given: 250
34
Here's a debate if ever there was one....
Copper is used on a lot of classic cars as it does indeed bend more easily than steel or kunifer, and is a bit cheaper IIRC. Problem is that copper will work harden from vibration and can become brittle as a result. While kunifer takes a little more effort than copper, it's a lot easier to work than steel.
Threads: 65
Thanks Received: 716 in 613 posts
Thanks Given: 226
50
The advice on the classic car Forums I use is to use Kunifer and not to use copper !
My own advice would be to use Kunifer.
Serieal Berlingo owner
