Threads: 9
Thanks Given: 316
15
If its not antifreeze and not the heater matrix?
Then the first place to start is cleaning out the scuttle - you will need to remove the wiper arms and remove the plastic grills. They get full of leaves and block the drain holes so water comes into the cab.
If its non of those things and i have found this - remove the driver and passenger seats pull the carpet back and get swambo to put the hose on the vehicle whilst you lie with your head under the footwells.
• Art b
Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
Had a leak test
and it look like a small amount of water is getting past or through the wiper motor.......?
called Brian...
