5
Threads:
Nov 2011
hi me agan no brake lights this time repaced bulbs and swich but still no brake lights ?
49
Threads:
13
Oct 2011
26-11-2011, 05:12 PM
(This post was last modified: 26-11-2011, 05:18 PM by wertyu2007.)
have you checked for power with volt meter and test switch continuity .[
cant see both bulbs blowing so id think faulty switch blown fuse first id check switch continuity it might be dud or bad connections .
20
Threads:
Jul 2011
quote='wertyu2007' pid='12965' dateline='1322327539']
[/quote]
Hi, we had intermittent problems with brake lights, even removed and opened the switch and cleaned the contacts.. this worked only a short while. A new switch was the only answer. They are not too expensive and available on ebay. Certainly cheaper than someone running into your rear end. Good luck.
Paappy
Threads:
Nov 2011
i had a simular problem but found out the swich needed adjusted as when the peddle was pressed it wasnt activating the switch , just unplugged it wound it in a few turns plug it back in now it works fine dont know if it will help you but thought i would share it with you anyway fella
good luck
