Threads: 20
Thanks Received: 17 in 14 posts
Thanks Given: 31
Hello all.
I am looking for the name, or better yet a place I can get a replacement sliding door guide. The plastic bit in the b pillar that the spike bit on the door locates in. Mine has now died and fallen out.
As a picture is worth a thousand words it is the black plastic square thing with a hole in. There are two on the pillar.
It's a 2001 1.9d with 322,500 k on the clock.
Threads: 20
Thanks Given: 31
This is a picture of both
Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
Try eBay vans breaking,
302k is quite impressive..
called Brian...
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
I suspect its a dealer only part as second hand ones will be worn out by now.
Its a sliding door locating pin and guide bush you are looking for.
• Carl.1
Threads: 20
Thanks Given: 31
The hard bit is finding the right one, the one on mine is a square shape with the round hole for the pin. Was hoping to find one on line so I can save time. All I find are a different shape.
Threads: 20
Thanks Given: 31
10-10-2018, 06:31 AM
(This post was last modified: 10-10-2018, 06:44 AM by Carl.1.)
Found them.....I love the Internet. In Estonia of all places! Local dealer said they could not get any! I suspect could not be bothered to try.
https://pood.hmkauto.ee/en
I also love it when dealers have the parts diagram so you can actually get the right part.
https://pood.hmkauto.ee/en/a/door-pin-sl...r-berlingo
The following 1 user says Thank You to Carl.1 for this post:1 user says Thank You to Carl.1 for this post
• Art b
Threads: 8
Thanks Received: 498 in 447 posts
Thanks Given: 301
31
(10-10-2018, 06:31 AM)Carl.1 Wrote: .....I also love it when dealers have the parts diagram so you can actually get the right part.
Pats diagrams until your eyes water.....
https://www.catcar.info/citroen/?lang=en
The following 2 users say Thank You to jj9 for this post:2 users say Thank You to jj9 for this post
• Carl.1, rublehousen
Threads: 20
Thanks Given: 31
Good gods alive, I just looked at that link and can not even work out which one I have!
Threads: 8
Thanks Given: 301
31
Try putting in your VIN number, some work some don't.
Threads: 29
Thanks Given: 67
20
(02-10-2018, 09:01 PM)Carl.1 Wrote: Hello all.
That bit is to locate the door as it shuts, door locator set, guide and pin. If anybody has them now they will be old stock, probably easier to find in a scrapyard. If it's damaged your door must be out of alignment and probably needs adjusting.
