Berlingo failed
Hi gis a not on this much so my beloved berlingo is good to me but just last night I was driving up to a roundabout reducing speed found it hard to go into Lower gear like  crunch in every gear the same o way up till 3rd heard a big crunch Nd thump now its stuck in gear and only able to move stick from gear it's in till 4th also when force it into reverse lights come on go to reverse it goes forward took it for a drive in 3rd gear when clutch released when accelerated the hole cab shock the life out of me could someone shed some light on this please thank you
Hi and welcome to the forum.
Its difficult to understand what you are talking about to be honest and it sounds like you have a very very limited knowledge of mechanics.
however i suspect your gear linkage is the first place to start if you want to have a go? Or tell your mechanic to start there, when this has been repaired or eliminated then let us know the outcome and we will go from there.
(04-10-2018, 06:45 AM)Deano Trevor Marshall Wrote:  Hi gis a not on this much so my beloved berlingo is good to me but just last night I was driving up to a roundabout reducing speed found it hard to go into Lower gear like  crunch in every gear the same o way up till 3rd heard a big crunch Nd thump now its stuck in gear and only able to move stick from gear it's in till 4th also when force it into reverse lights come on go to reverse it goes forward took it for a drive in 3rd gear when clutch released when accelerated the hole cab shock the life out of me could someone shed some light on this please thank you
dude i wanna help u but i dont understand so much..
Tecnovent
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
