Weird noise when reving engine and driving along
Hi all,
My 2008 1.6 diesel has a weird noise when you rev the engine and also you can her it when driving along. Its like a whizzing noise
Any ides please ?
First check would be the auxiliary belt, make sure it's in good condition.
Get your head under the bonnet and get someone to rev the engine so you can maybe narrow down where the noise is coming from.
Its one that is impossible to answer i would just be guessing and that may just waste your time and point you in the wrong direction.
I had a split in the boost pipe on my Audi ..
it sounded like the window was slightly open..
The power was just not there..!
called Brian... Smile
The sound is VW owners sucking in their breath at seeing a 1.6TD that isn't such a flagrant breach of emissions codes as their own...
[-] The following 1 user says Thank You to Gadgetman for this post:
  • Art b
Check the level of your power steering fluid..
(07-10-2018, 11:42 PM)banana1975 Wrote:  Check the level of your power steering fluid..
I'd go for the pulleys on the Aux belt - if you unhook the belt and start her up without it fitted you can test them.
              2008 1.6  HDi 110 Mini (Hers)
              2008 1.6  HDi 143 Mini (His)
Mine does a similar thing, I've assumed it's the aux belt. Unfortunately I couldn't start the engine to check it when I had the belt off due to the radiator being out & having no fresh coolant at the time.
I did turn the various pulleys by hand and check for play but all seemed fine.
If the weather is nice as forecast, I'll take a look at getting the belt off later in the week.
I posted here before, I had a squeal, that I thought was an aux belt or time belt, ended up being a blocked cat convertor, exhaust blowing out the joint made the sound
Cheers for help, today i removed the belt and started and it didn't make the noise so its  definitely drive belt related. Spun up the tensioner and idlers but all seemed ok. Fitted new belt and its a bit quieter. I was wondering if it could be the Alternator clutch pulley ? anyone changed theres?
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
20-04-2026 02:30 PM
Last Post: jw4821
20-04-2026 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
