Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 6
Hi, this is my first post. I have a 2008 1.6 hdi 166k.
Had it a couple of months and it's been ok and very nippy! Recently the power seems to have gone, there's no oomph in it anymore. Before I used to put accelerator down and it was very perky, now very little happens.
Any common probs that can cause this, feels like something blocking it from going!
Threads: 123
Thanks Given: 250
34
It could be that your MAF has failed, but I'd expect the EML & 'Anti Pollution Fault' to be displayed. It's quite easy to disconnect the MAF and see if it makes a difference but it's probably best to get an OBD code reader, they're cheap enough on flebay.
Thanks Received: 22 in 20 posts
Thanks Given: 35
05-10-2018, 06:37 AM
(This post was last modified: 05-10-2018, 06:39 AM by frank.)
yes a bluetooth obd is very useful for diagnosis, you can check if the turbo is boosting too
Threads: 2
Thanks Given: 6
So if I disconnect the MAF and it's exactly the same will that point to the fault or should it run better?
Think I have a Bluetooth OBD reader, will that test the turbo?
Threads: 3
Thanks Received: 13 in 7 posts
Thanks Given: 1
A standard unmodified 1.6 HDI 16v should make a bar of boost I think, according to the OBD thingy I've used. Does your speedo work correctly by the way?
Threads: 2
Thanks Given: 6
Hi, ive disconnected the airflow sensor and tbh it does run slightly better at low revs but still missing the acceleration when I floor the accelerator, like it did before.
For some reason the bluetooth OBD tool I have wont connect to the ECU but it works fine in my Focus.
Any ideas ?
Thanks Given: 35
mine,s a black xtrons one, £6 on ebay
and my boost often registers 1.25 bar (depending what gear or rpm) but then settles at about .9bar
