Threads: 3
Thanks Received: 3 in 1 posts
Thanks Given: 6
Simple quick question is
Can you set the date and time on the dash display without having the factory stereo unit fitted ?
I have fitted an aftermarket stereo unit and disconnected the battery the other day to do some work on my berlingo and im just asking before have to go a pull my stereo out and plug the original in just to set the them.
2010 berlingo.
2010 BERLINGO MULTISPACE XTR
Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 5
I have the same problem. My lingo,bought sh, came with an aftermarket Kenwood DAB radio.
the clock worked ok until I changed the battery after which the clock just flashes. No amount of knob twiddling and button pushing would allow me to set the clock. even a friendly AA man thought he could make work but he gave up.now i just use the clock on the radio and try to ignore the flashing digits. Best of luck
LL61OSY
Threads: 3
Thanks Given: 6
In the end last night I just pulled the tray out underneath my stereo for easy access to the stereo wires and plugged in my factory head unit set the time and date it took about 2mins then I plugged my aftermarket stereo back in realising it had wiped all the settings on it as that had been unplugged !! Hassle but I couldn’t stand the flashing clock.
Threads: 7
You should be able to use the stalk on the rhs of the steering wheel to change date and time.
Threads: 3
Thanks Given: 6
(09-10-2018, 02:14 PM)WMoto Bikemad Wrote: You should be able to use the stalk on the rhs of the steering wheel to change date and time.
With the aftermarket stereo fitted the right volume stalk doesn’t work at all as it’s not connected
Threads: 3
Thanks Given: 6
(09-10-2018, 01:26 PM)cancunia Wrote: (09-10-2018, 01:20 PM)6545george Wrote: In the end last night I just pulled the tray out underneath my stereo for easy access to the stereo wires and plugged in my factory head unit set the time and date it took about 2mins then I plugged my aftermarket stereo back in realising it had wiped all the settings on it as that had been unplugged !! Hassle but I couldn’t stand the flashing clock.
There was someone on here a while ago asking about setting the language after fitting an aftermarket radio. Did the language come up as an option?
Yes I’m sure with the original stereo fitted there is a language option I didn’t look into it cause I need it in English but I’m guessing it’s a matter of selecting it and then choose your language
Threads: 7
Thanks Received: 42 in 35 posts
21-10-2018, 08:07 PM
(This post was last modified: 21-10-2018, 08:08 PM by hawaiianblue.)
I wonder if it might be possible to swap the display for one of the PSA displays with buttons on? The first gen C5 for example has a display with buttons on it for setting the time. I think there are several Peugeot units that have the same too. It would avoid the need to connect up the factory head unit just to change the time.
