07-10-2018, 05:44 PM
(This post was last modified: 07-10-2018, 05:45 PM by Robbie87.)
I’ll Hi guys, I own a 62 plate Citroen van 120k. Had it serviced two weeks ago, once serviced my local garage said it was due a timing belt at 107k which it hadn’t had so I book it in for Wednesday just gone. Had a new timing belt water pump and fuel filter cost me £420 all in, van has been fine up until this morning when the engine fault has come on the dash shortly after I’d filled the tank up with diesel it also seems like I’ve lost the power still drives but takes longer than normal to pick up. Any ideas what it could be and if it’s anything to do with what work has been done. Cheers
Threads: 9
Thanks Given: 316
15
Hi Robbie and welcome to the forum.
To be honest mate it could be anything and you do need to get the vehicle on a diagnostic machine before you go any further.
I could be something to do with the work that was done if a sensor or wiring was damaged, or if some of the work has not been completed correctly. Intercooler hoses loose - anything really
