Mounting bolts for caliper
Music
hello  two of mine mounting bolts for the caliper holder is almost stripped. and I need some new ones.
do I need to use the original bolts or just som regular ones with same dimension and torx head?
i see that the unoriginal has a little smaller head than the original type ones
need the front and back as in picture
[Image: 9678008680.jpg]
[Image: 440547.jpg]
original numbers
440547
440553
The original ones will stay tighter & spread the load wider because of the larger head, they may also have different tensile strength. If you can get the originals, they would be best.
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
