2004 1.9d engine removal
I will be fitting new clutch assembly and a cam belt kit,
would it make life easier if I removed the engine and gear box,... Confused
how long might the engine removal take .. Huh
thx in advance
called Brian... Smile
Roundbouts and swings ...... I'd leave the engine in place ... I've done both jobs in the past.
edit : Time - lazy diy for a clutch took me a Saturday 09:00 to 16:00 and 10:00 to 12:30 hrs on Sunday, as I say very lazy but then I am retired and under no pressure of time.
Timing belt usually takes me four hours on the same basis as above  Heart
  • Art b
Leave the engine in place.
  • Art b
(08-10-2018, 04:07 PM)geoff Wrote:  Roundbouts and swings ...... I'd leave the engine in place ... I've done both jobs in the past.
Thanks Geoff... Smile
I've plenty of time as this is a project car,
Did you use a manual for information on the clutch change,
or another source...
I've just got a full clutch kit on eBay for £19... Big Grin
(09-10-2018, 06:40 AM)polar Wrote:  Leave the engine in place.
I think it's best,
to avoid messing about with fuel,exhaust,cooling etc...
I used the Haynes manual as a reference for both of these jobs.
Even if you are experienced it is always worth a quick read before doing a job for the first time on a new / different vehicle as indvertent error on valve timing can prove rather expensive.
There is a Haynes Manual for free download on this site, have a search.
Whilst at it replace the aux belt they only have a short service interval premature failure can take out the entire engine if unlucky.
Have fun it isn't a tough job.
  • Art b
(09-10-2018, 10:53 AM)geoff Wrote:  I used the Haynes manual as a reference for both of these jobs.
Thanx for the advice,, Cool
I've done a few belts,
And the odd clutch ..but not on a fwd...
[-] The following 1 user says Thank You to Art b for this post:
  • geoff
Up she goes...
That should make clutch and belts replacement easier... Smile
(09-10-2018, 08:14 PM)Art b Wrote:  Up she goes...
Attached Files Thumbnail(s)
  • geoff
No half measures eh! Wink
Injector/Cam Larder Studs 1.6 HDI
Last Post: saskak
Yesterday 01:07 PM
» Replies: 52
Engine noise
Last Post: cancunia
21-02-2019 10:03 AM
» Replies: 21
clutch pedal
Last Post: ffrenchie
20-02-2019 08:06 AM
tensioner pulley
Last Post: RJBingham
17-02-2019 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
12-02-2019 04:23 PM
» Replies: 31
