[Engine] Adding Keys with Lexia
Threads: 121
Thanks Given: 248
34
08-10-2018, 05:11 PM
(This post was last modified: 08-10-2018, 05:12 PM by cancunia.)
I only have one key so am thinking about getting another, but I'm not 100% certain if I have the correct code for Lexia so want to check before I decide to get a key & add it myself or get the existing one cloned. I know that I can get the code from a dealer but would like to see if the one I have is correct.
Does anyone know if Lexia will tell you that your code is wrong on the first entry of 2 or only after the second time you put the pin in?
If I put the correct code in twice, can I back out of the programming without adding any keys or changing anything?
If I put the wrong code in, is there a limit to how many times I can do that?
As you may be able to tell, I'm not used to Lexia and a bit paranoid, especially when I remember the post where someone was checking things out and managed to delete all his keys!
Thanks.
Threads: 13
Thanks Received: 136 in 111 posts
Thanks Given: 162
15
Threads: 121
Thanks Given: 248
34
Thanks brajo,
I found a helpful guide on youtube, it shows all the steps to add keys but the person doing it knew he had the correct code. My situation is slightly different as all I really want to do at the moment is check if I have the correct code.
Threads: 59
Thanks Received: 253 in 215 posts
Thanks Given: 228
29
(08-10-2018, 05:11 PM)cancunia Wrote: I only have one key so am thinking about getting another, but I'm not 100% certain if I have the correct code for Lexia so want to check before I decide to get a key & add it myself or get the existing one cloned. I know that I can get the code from a dealer but would like to see if the one I have is correct.
Thanks.
Hi Cancunia,
I think you can re-program another key without deleting any other already working keys. I did this myself. Deleted one of my keys and then the car did not start with that one, was only turning but could not start. My second key was working without a problem. So, I re-programmed the "deleted" key and it was working again.
If you get a key, it should not be a problem to re-program it. If the code is incorrect, you would not be able to re-program it, but this should not affect your existing one.
Hope this helps.
Cheers,
Saskak
Threads: 121
Thanks Given: 248
34
09-10-2018, 10:38 AM
(This post was last modified: 09-10-2018, 10:38 AM by cancunia.)
(09-10-2018, 09:35 AM)saskak Wrote: I think you can re-program another key without deleting any other already working keys. I did this myself. Deleted one of my keys and then the car did not start with that one, was only turning but could not start. My second key was working without a problem. So, I re-programmed the "deleted" key and it was working again.
Thanks for your reply. The Lexia example that I saw on YouTube seemed to say that you need to add all of your keys, or to put it another way, any keys you don't add will no longer work. There's also a warning about using the wrong code.
https://www.youtube.com/watch?v=tIVFSDQjHIA
It's all a question of money in the end. I have a local locksmith who will cut & clone a key for £40, or there's a seller on ebay saying they will supply a cut transponder key for £20, but then I'll need to add it via Lexia. I have Lexia & I like the idea of saving £20 plus a 40 mile round trip.
Threads: 121
Thanks Given: 248
34
09-10-2018, 11:25 AM
(This post was last modified: 09-10-2018, 11:26 AM by cancunia.)
I called my local Citroen garage to see if they can verify my code.
It turns out that there are a couple of options.
1, They can call Citroen, it costs them about £12.50 so to get it from them costs £12.50 + whatever margin they decide to add +VAT so approx £15+
2, They can order a new code confirmation label, this costs less but probably takes a while.
I think the second item is what I already have & so will take it down to the dealer to check when I'm next in town.
Threads: 7
Thanks Received: 8 in 8 posts
09-10-2018, 11:51 AM
(This post was last modified: 09-10-2018, 11:55 AM by gazthelad.)
try your code,don't worry lexia will not let u go any further if security code is wrong...if code is good,no problem..put original key in first,then simply follow the instuctions on screen.....-------don't forget sychronise keys after programing
if u put wrong code in the second part...lexia will tell u it does not match..and go no further,until right code is put in..
Threads: 121
Thanks Given: 248
34
(09-10-2018, 11:51 AM)gazthelad Wrote: try your code,don't worry lexia will not let u go any further if security code is wrong...if code is good,no problem..put original key in first,then simply follow the instuctions on screen.....-------don't forget sychronise keys after programing
Thanks, I'm probably worrying too much about this, it's just the thought of not having any working keys!
On the putting the code in twice bit, does it reject the first entry if it's wrong or does it wait for the second entry before it tells you?
Threads: 7
09-10-2018, 02:49 PM
(This post was last modified: 09-10-2018, 04:44 PM by gazthelad.)
lexia will reject wrong code 1st or second.........if u have right security code u can program keys.........but they have to be virgin keys......[so the key u have does it start car and open doors]......if so ur good to go........
SECURITY KEY CODE MARRIED TO VEHICLE..it will not accept any other key code......
Threads: 121
Thanks Given: 248
34
Today I added my second key while holding my breath, all was well, I now have 2 working keys and 1 remote.
To answer my own question, after adding the keys, I also tried to enter an incorrect code. Lexia did not complain on the first entry and asked for the code to be entered again. So, AFAIK the only way to know if you have the correct code via Lexia is to go through the key programming process.
Today 12:00 AM
Berlingo multispace Clockspring issue
Yesterday 11:39 PM
Phone call in progress
Last Post: Leonberger
Yesterday 09:11 PM
M49 wiper blades
Yesterday 07:48 PM
DV6C 9HL injector options
Last Post: KD305
Yesterday 06:25 PM
brake master cylinder
Last Post: BigVtwin996
Yesterday 03:28 PM
Hello
Last Post: OMG
Yesterday 01:11 PM
Passenger seat warning light by pass
Last Post: Bluebottle
Yesterday 11:37 AM
How to identify knocking injector
Yesterday 10:35 AM
Dangel 4x4 rear brake discs
Last Post: dwr400
Yesterday 05:00 AM
