How to test Stop Solenoid
Guys how do you test a three wire stop solenoid, I have removed it of the armoured casing..No click
Citroen berlingo 1.9
2003
WYJ
3 wire ones are dual coil aint they ? pull coil and holding coil, so a common wire and a wire to each coil
(16-10-2018, 07:37 PM)frank Wrote:  3 wire ones are dual coil aint they ? pull coil and holding coil, so a common wire and a wire to each coil
I want to test it using a battery or something, cause advise given i don't understand.There are three wires as the image...which is which
Attached Files Thumbnail(s)
you would need an ohm meter to find which wire goes where, does it click if you turn the ignition on ?
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
