[Transmission] Gear linkage
Thumbs Down
Wondering if anyone can help me out with this, i have a 2007 1.6 diesel multispace where the throw on the gearstick has become noticeably stiffer in the last fortnight. Does anybody know what this could be ? Many thanks David.
Below is a diagram of a typical Berlingo gear linkage set up.
Try lubricating all of the balls at the end of the rods, (# 2, 3, 4, 5) and any other moving parts in the area. (spray grease)
The connections at the base of the gear stick could also need lubrication.
Get a helper to move the gear stick through the gears so you can see how the linkages work from under the bonnet and you may spot something that looks suspect.
[Image: 15435d1305025184-berlingo-gear-linkage-b...o_gear.jpg]
  • polar
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
