Threads: 5
Thanks Received: 3 in 2 posts
Hi does any one know where i can buy the copper washers for the delphi cr6736001 deisel injector
i have searched e bay and they only have the bosch ones, the size is 20mm and inner diameter 16.6mm
The ones on the van are leaking so not worth annealing again.
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
First one I found.... M16 x 20mm x 1.5mm
https://www.ebay.co.uk/itm/Metric-Copper...2552799971
Any good?
Threads: 5
It has to be 16.5, very difficult to file the inner ring, its really strange i can't find them as they are essential for a tight fit, the ones i have in at the moment are leaking diesel and bubbling, also i think this is causing a pressure drop and causing the injectors to leak.
In the morning the van will not start without easystart.
I have changed the nozzles in all injectors, fitted new gasket to fuel filter and checked fuel lines, it has to be the o rings? where can i get them? oh yes i have a brand new injector,unused.......no copper washer?
Threads: 8
Thanks Given: 305
35
Citroen have the washer listed as 16.8mm x 20mm x 1.5mm
part # 1981 33 ... £0.78p each
The following 2 users say Thank You to jj9 for this post:2 users say Thank You to jj9 for this post
• Art b, ron
Threads: 8
Thanks Given: 305
35
Just to add,
don't overlook the leak off pipes that go from injector to injector, they become brittle and if they aren't air tight they will let in air and cause poor starting due to the fuel leaking back.
• Art b
Threads: 8
Thanks Given: 305
35
The part number is correct.
I looked the part up on Citroen service box, I went through the process of buying the part that's how I know the price.
You may not have access to service box so the alternative is the site below. (part #12 in the diagram)
https://www.catcar.info/citroen/?lang=en...I9PQ%3D%3D
Any Citroen / Peugeot dealer will be able to order the parts.
Threads: 5
Thanks for your help again,can i ask you if you have used this site before?
it wants a lot of information....and will not give me the price...is it in Russia?
Threads: 8
Thanks Given: 305
35
Citroen have a site called Service Box but you have to have an account to access it, it was here that I got the part number and price from.
I couldn't put up a link to the diagram on the Citroen service box site because you wouldn't have been able to see it as you don't have an account, so I looked up the part on the catcar site and put a link to that so you could see it along with the part number.
I use the catcar site a lot to get part numbers (as do other forum members) and you also have the ability to post a link to the diagrams which is helpful on the forum when trying to explain or point out items.
If you get the part number from the catcar site you can order the parts at any Citroen dealer using the part numbers as they are the same as the numbers on Citroen service box.
