[Transmission] 2004 gearbox removal difficulty...
I have partly removed the gearbox, [clutch replacement]
on my 1.9 d
its all disconnected  eased away from the engine by 3 inches
and sitting on jacks and blocks..
BUT... I can't seem to get the rear of it past the subframe
do I need to lower the subframe.. Huh
called Brian... Smile
Cannot remember exactly as too long back now but I don't think you need to.
There is a good description in Haynes - manual free to download off this site.
  • Art b
(18-10-2018, 08:46 PM)geoff Wrote:  Cannot remember exactly as too long back now but I don't think you need to.
Supurb..thanx for the tip , Smile
I've downloaded the manual,
And it looks like removing the rear engine mount is the way forward, Confused
I presume this allows the engine to move forward slightly , to enable the gearbox to clear the subframe
I know the clutch change in the video below is on a Renault Clio but maybe you could use the same principal.
If you drop the gearbox right down it's always hard work getting it back into the gap.
https://www.youtube.com/watch?v=wZe6Tnhygss
  • Art b
(18-10-2018, 10:00 PM)jj9 Wrote:  I know the clutch change in the video below is on a Renault Clio but maybe you could use the same principal.
thats an interesting idea,
but the gearbox does not have enough clearance past the subframe,
I like the idea of super glue on the friction plate .. Cool
Well I had to lower the subframe by 2inches to get the box past.. Huh
probably because the OS. drive shaft would not come out easily Angry
Was the intermediate bearing of the O/S driveshaft seized into the housing?
(21-10-2018, 03:17 PM)Mankee Wrote:  Was the intermediate bearing of the O/S driveshaft seized into the housing?
Maybe..
tbh it's the 1st fwd I've done,  Confused
and I struggled to understand the OS driveshaft intermediate bearing housing... Huh
Now the box is out of the engine bay,
I will investigate the intermediate bearing housing..
Thanks for you input..
For the intermediate bearing, there are two "hockey sticks" which retain the bearing in the housing bolted to the back of the block. You need to undo the 11mm nuts, swing the heads of the hockey sticks out of the way and the bearing (and driveshaft) can be freed from the housing.
[-] The following 1 user says Thank You to Mankee for this post:
  • Art b
(22-10-2018, 10:40 AM)Mankee Wrote:  For the intermediate bearing, there are two "hockey sticks" which retain the bearing in the housing bolted to the back of the block. You need to undo the 11mm nuts, swing the heads of the hockey sticks out of the way and the bearing (and driveshaft) can be freed from the housing.
I have the bolts moving..
 need to have a play to get the drive shaft out..
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
