Berlingo over reving when changing gear
Hi,
Looking for a bit of advice.... I have a 56 plate berlingo van 1.9 and the clutch sounds very heavy but it has been driving fine until yesterday, when I put the clutch pedal down to go into 3rd it’s l keep the he engine over revs and it jumps forward, anyone any ideas, thanks!
Hi and welcome to the forum
I wish i could understand what you are saying? Are you sure its a 1.9 and not a 2.0hdi engine for a start?
I’ll explain better, I put it into third with the clutch still down and when I lift the clutch the revs go up and it jumps forward, it has been intermittent today. It’s defo 1.9 thanks
(20-10-2018, 09:50 AM)GraemeTinney Wrote:  I’ll explain better, I put it into third with the clutch still down and when I lift the clutch the revs go up and it jumps forward, it has been intermittent today. It’s defo 1.9 thanks
There could be a micro switch on the clutch pedal buy why its only happening in 3rd is a very odd one.
I wonder whether the gear selector linkage is worn and its not selecting 3rd correctly? That is the place i would start inspecting the gear linkage for play in the gears. How many miles has the vehicle done? Does it do anything strange other than this fault?
  • Art b
clutch problem mate
berlingo b9 2009
Check the cable & release bearing pivot shaft are free before you do anything else.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
