2.0 HDI - pre-heaters not working?
Threads: 5
Thanks Received: 8 in 2 posts
Thanks Given: 3
28-11-2011, 09:11 AM
As the weather has got colder the Berlingo has got harder to start. The pre-heater lamp doesn't illuminate at all, which could of course just be a blown bulb. Anyone able to suggest a quick way of checking if the heaters themselves are functioning?
I suspect a new battery may be on the cards too as after the first few seconds it's not turning over very quickly (fortunately so far it's fired up before it's given up, so to speak) but I'd like to know if the pre-heaters are working before the weather really turns cold.
2004 Berlingo Multispace Forte 2.0HDi in red.
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
Hi Snaprails.
At first, check fuses in BSI, BSM and PSF(if you car has it).
Threads: 5
Thanks Given: 3
(28-11-2011, 09:16 AM)pk7478 Wrote: Hi Snaprails.
PSF?
According to the book of words the preheat shares a fuse with the reversing lights, I checked and they work. Is there another fuse I should look for?
Googling and searching this forum does suggest that the lamp rarely comes on unless it's below freezing so maybe my thoughts re battery may be close to the mark, will have to get torch out later and see if there's a date on it.
Threads: 25
Thanks Given: 44
12
28-11-2011, 10:58 AM
(This post was last modified: 28-11-2011, 10:58 AM by pk7478.)
(28-11-2011, 09:49 AM)snaprails Wrote: (28-11-2011, 09:16 AM)pk7478 Wrote: Hi Snaprails.
PSF?
PSF - small fuse box under BSM.
VIN of you car to my PM, please.
Threads: 63
Thanks Given: 410
Quite well documented/discussed in other threads.Please do a search for other replies within the forum....
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Hi, "PFS" is the engine bay fuse box, Check fuse 1 (10A).
Also check the connection on your water temp sensor which is below the vaccuum unit on the end of the camshft.
Mine's a green plug/socket with 2 wires - one yellow, one white.
Cheers :thumbsup:
2006 2.0hdi 600 with bench seat.
The following 1 user says Thank You to Rustscrat for this post:1 user says Thank You to Rustscrat for this post
• pk7478
Threads: 25
Thanks Given: 44
12
(28-11-2011, 11:20 AM)Rustscrat Wrote: Hi, "PFS" is the engine bay fuse box, Check fuse 1 (10A). BSM calls PSF in diagrams.
PCF it's other unit.
Threads: 5
Thanks Given: 3
Update:
All fuses checked ok. Weather finally got cold enough for glow plugs and lamp lit. At which point the battery, which tested fine decided enough was enough. New battery and things are much better, not exactly bursting into life as soon as the key turns but much more able to turn the engine fast enough for it to fire within 10 secs.
Threads: 41
Thanks Given: 82
6
17-12-2011, 06:14 PM
(This post was last modified: 17-12-2011, 06:15 PM by Mike.)
I've marked this as solved as it sort of solved itself - can still be posted on though..
Threads: 63
Thanks Given: 410
My battery has been showing signs of giving up for a while now but after initial slow turn over from cold it is ok all day.
Yesterday was the first time this new season that the pre-heater light came on on the dash. It seemed to stay on for quite a while considering it was only just around freezing. Last winter in temperatures of up to minus 15-20 deg C, the light just flashed for a split second and she fired up straight away. Did not go on first turn yesterday so went back through a full start procedure to see if the light came on again. Stayed on a while then after turning the key, fired up straight away no white smoke or anything....
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
