  • 30 Vote(s) - 3 Average
[Engine] reverse light switch
Hi!
How can I change my reverse light switch by myself?
berling 1.9 2006
thx Smile
Shalom.
It's very easy. Head and hands. It is all what you need Smile
In defence of PK,I think he meant only that it was a simple job.I wish my Russian was 1/2 as good as his English.
  • pk7478
Seconded.
I don't think that any offence was intended
@ Ron. Don't mean to be pedantic but does that post talk about the brake light? The reverse light switch is in the gearbox. It's fairly easy to spot and easily accessed from the front of the car iirc. Look to the left of the battery on the gearbox disconnect the connector and unscrew the switch. You'll see the brass plunger in the end of the switch will be worn or it just wont work (try a continuity test). It is a 10 minute job.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
(28-11-2011, 10:00 PM)ron Wrote:  it was a simple job.
Yes Ron. I mean namely this Smile
In fact It is not necessary to drain a geardox out or unmount something terrible like CVs or gearbox itself.
@fdanfn Please, see a picture below. Reverse sensor is on position no.19
[Image: begearbox.jpg]
Can somebody please post an idiot proof diagram for complete newbie on where to look, etc.
Reversing lights not working, both bulbs gone, replacement bulbs dont work. Want to check switch before coughing up for an auto electrician.
Many thanks
@Berl
Did you sort out the issue with just the switch ?
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
