Threads: 9
Thanks Received: 6 in 6 posts
Hi, I decided to refurb the fuel injectors in my 1999 berlingo 1.9 diesel van, all was going well until I tried to renew the seat washers to reinstall the injectors. Citroen can't help ( discontinued) , most of the diesel specialist I have tried can't supply either , the washers are a critical part and need to be right in order to complete my task , as anyone any thoughts.
Threads: 9
Thanks cancunia for replying , I managed to source the much needed washers from a specialist diesel injector company. These injectors on my van are of the "old type" and nobody carries spares because of its age, and why would they ? . Diesel engines in the Berlingo are much more sophisticated, will put all back together at the w/end. A Citroen dealer i contacted previously put me onto the specialist which I thought was good of them, it sounds cheesy but I like the van it starts and goes no problem and although it's slow it's reliable. Thanks again for getting back to me
Threads: 123
Thanks Given: 250
34
You're welcome. Were your washers solid copper, or the crush variety?
Threads: 9
Thanks Given: 316
15
You will need both types od washers cancunia posted links to the steel ones fit inside the copper ones and are called heat seal.
Threads: 9
The washers i removed were copper but no heat shield washers were present, I wasn't advised at the diesel specialist that it should have them ?, looking at my fitment I can't see how you could fit the steel type .
Threads: 9
Actually cancunia it looks like your right, the steel washers are not loose enough to come out and looked like part of the recess where the injector fits. I think it's time for an eye test
