EXHAUST POWER LOSS
Please help when i remove pipe coming exhaust manifold,  the engine idles perfect...if i put it together it cuts off....see the picture
Attached Files Thumbnail(s)
That's the pipe for the EGR. It could be a fault in the EGR Valve , like the flap sticking down and not letting air into the engine .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(02-11-2018, 09:08 PM)brodfather11 Wrote:  That's the pipe for the EGR.  It could be a fault in the EGR Valve , like the flap sticking down and not letting air into the engine .
Thanks for the reply
The flap is in a flat position, i have two of them and they both act the same way
air filter OK and nothing blocking the air supply for the engine ?
When the engine is idling, the egr valve should remain closed. No exhaust gases should be introduced into the inlet manifold, because this would interfere with the ecu default idling mixture, which is critical for smooth idling.
If your egr is remaining open when idling, this could cause the engine to falter and stop. Your troubles look like an egr malfunction.
Gravity
my understanding is that the egr is only open at idle
is this egr vacuum valve working ok ?
(04-11-2018, 01:47 PM)frank Wrote:  my understanding is that the egr is only open at idle
What ever happens the the erg stays open, and i just discovered that even if i disconnect the ECU the van still runs....am now absolutely confused
How do you test or see if it works or not
the ecu controls it via vacuum, it should be pulled open when idling
That is controlled electronical or
Today 12:29 PM
Yesterday 07:46 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
