Wheel bolts for steel wheels
Hi,
Have a 2016 multispace xtr with 16" alloys.  Have just bought some winter steelies (ALCAR 8477).  Can anyone tell me if I need new bolts for with these?  They look like they need a tapered bolt.  Have taken one of the original bolts off and these don't look suitable.
Many thanks in advance,
N.
Yes Steel wheels will need new bolts.
Usually dirt cheap from a breakers yard and will be the same ones on C4's and 307's if not the whole PSA range.
Just make sure you get all the same size heads on them, Citroen did change the size of the head on most of their range at one point - the threaded part of the bolts are the same, it's just you need a different size wheel brace to fit them.
[-] The following 1 user says Thank You to hawaiianblue for this post:
  • nicknameless
Sorry still confused!
Isn't the spare a steelie intended for the same bolts?
Also descriptions of this wheel (ALCAR 8477) suggest it is specifically manufactured for the blingo / partner etc. and therefore can use the original bolts.
Confused.com
[Image: X-5-Wheel-Bolts-Nuts-Screws-Studs-Alloy.jpg]
If the bolts from your alloy wheels look like the bolts in the picture yes they will secure a steel wheel but they stick out and don't look like they are fastened properly.
Looking at the bolt, the taper part  just up from the thread is the part that holds the steel wheel, the flat part with the washer on is the part that holds the alloy wheel.
Try your steel spare on and you'll see what I mean about them sticking out.
You will need a set of bolts for steel wheels.
  • nicknameless
Ok many thanks.
M12 x 1.25
Tapered?
Thread length?
(12-11-2018, 01:54 PM)nicknameless Wrote:  Sorry still confused!
Confused.com
The steel spare is only intended as an emergency replacement, so the alloy bolts will hold it but look terrible and the washers on them will rattle and go rusty.
It's unlikely the wheels that you've bought are specific to the Berlingo, they'll just be the right dimensions/load rating, and will likely fit a range of vehicles which have the same spec - much like tyres.
Get in touch with any breaker and ask for a set of wheel bolts from a Berlingo van.
[-] The following 2 users say Thank You to hawaiianblue for this post:
  • jj9, nicknameless
Leaking windscreen or aerial
Yesterday 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
