Heater/blower replacement
Hi there. Hope your all well.
My blower has stopped working in my m69 van.
I have a replacement and I am wondering if there’s any guides to removal and refit??
Thanks in advance
theres a lot covered on the blower, some say its only the resistor needs replacind, or the green box relay, or both, all of which are difficult work to fix, depending on the model of your berlingo,
on mne, the blower is behind the foot brake, B9, up and over , here youll find the resistor, attached,
if your blower works on number 4 only, its your resistor, also ytr the relay, a small green one behind glove box, easily spotted , bright green cube, youll find ideas on the forum if you look around, good luck.
Citreon will do it for you 300 pounds....lol
berlingo b9 2009
Thanks for the reply.
Mines the b59 2010 model. I don’t think it’s the resistor. It’s not working atm but when I hit a pot hole it sometimes comes on but sounds like something is loose or broken
(12-11-2018, 07:30 PM)Chri5 Wrote:  Thanks for the reply.
have a look at relay, green box about an inch , may have a wire loose, it has 3 wires connected,  behind glovebox... cheers
berlingo b9 2009
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
