Major investment time.
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Engine service.
Full new exhaust system.
Timing belt and water pump.
Nearside front strut mounting.
Hopefully that should keep it going for another few years.
2001 with 112k miles on.
Malcolm.
2001 1.9D Multispace.
Threads: 67
Thanks Given: 237
50
Only just run in .... happy motoring !
Serieal Berlingo owner
Threads: 24
Thanks Received: 39 in 35 posts
Thanks Given: 487
(13-11-2018, 10:18 PM)malgpz900 Wrote: Engine service.
Malcolm.
Are you doing any yourself...
My berli is laid up for the winter ,
I've done a new clutch,
Started the cambelt and water pump,
(the belt has been done at some stage,but not the pump..)
2004 with 119k
called Brian...
Threads: 48
Thanks Given: 4
20
112K miles?
Isn't it about then that it should have a valve adjustment?
The following 1 user says Thank You to Gadgetman for this post:1 user says Thank You to Gadgetman for this post
• ron
Threads: 22
Thanks Given: 8
14-11-2018, 09:49 AM
(This post was last modified: 14-11-2018, 09:50 AM by malgpz900.)
(14-11-2018, 07:46 AM)Art b Wrote: (13-11-2018, 10:18 PM)malgpz900 Wrote: Engine service.
Malcolm.
2004 with 119k
I did engine service.
Did clutch when bought it 8 years ago.
Did starter motor.
The I started using a local mobile mechanic.
He fitted front spring I had bought £30.
He fitted the timing belt and water pump £55.
He is doing the front spring mount.
The local exhaust centre fitted full exhaust with cat for £150 2 years guarantee (£30 fitting included in price).Priced the parts myself at £105.
Sometimes its not worth getting hands dirty.
Malcolm.
The following 1 user says Thank You to malgpz900 for this post:1 user says Thank You to malgpz900 for this post
• Art b
Threads: 24
Thanks Given: 487
(14-11-2018, 08:02 AM)Gadgetman Wrote: 112K miles?
is that shims on the cams..?
called Brian...
Threads: 67
Thanks Given: 237
50
......... Yes
• Art b
Threads: 24
Thanks Given: 487
(14-11-2018, 01:45 PM)geoff Wrote: ......... Yes
any info on it,... mines done 119k ...
called Brian...
Threads: 22
Thanks Given: 8
(27-09-2018, 07:39 AM)cancunia Wrote: (26-09-2018, 05:32 PM)WayneO Wrote: Hi all, i have decided to keep the Berlingo and camperise it,,,is that a word, heck must be i said it lol.
One thing i want is the front seat/s to fold flat forward, which seats are usually used ?
Wayne
What year is your Berlingo - 2005 from your other post? If so, the B9 seats may not fit without some faff but it may be worth the effort.
In my 2004 Berlingo, I used a folding seat from a van in the passenger side, the steering wheel is always going to be an issue though so for that side I modified the recliner so the seat tips forward beyond vertical. There are a few posts on that subject so a quick search should show what's needed.
Shhhhh. Don't tell the car!!!!
Keeping fingers crossed on that one.
Malcolm.
Threads: 67
Thanks Given: 237
50
(14-11-2018, 06:57 PM)Art b Wrote: (14-11-2018, 01:45 PM)geoff Wrote: ......... Yes
Lots of info on the Forum do have a search, I and others have written on it before.
Typically you need to consider adjusting the valve clearances if when at the onset of cooler weather you find the vehicle more difficult to start and initially has lumpy running, this will then get worse when the weather gets even colder.
If you don't have such an issue then really speaking you won't need to do anything.
Ideally the time to do the work is when you have a service interval that requires the timing belt to be replaced as this has to de done in order to make the adjustments - it requires the camshaft to be removed.
You can with little work remove the rocker cover and with the engine rotated to the correct positions for each cylinder make a measurement of the valve clearances and after comparison to specified gaps have an idea of where you are with it all and if required plan the job in to your schedule.
• Art b
Users browsing this thread: 2 Guest(s)
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
